20 Most Recent Broderbund Calendar Creator 12 for PC Questions & Answers
As far as I can tell ther is no way to change the line spacing on the Calender Creator Delux edition. However, there is a work around. You can find out how here: Margins Line Spacing.
Hope this helps!
Broderbund... | Answered on Feb 05, 2015
See this... http://forums.encoreusa.com/tm.asp?m=47646
Also, you could go here, click on the closest problem, and if it does not solve yours, at the end will be options to contact Technical Support. http://support.encore.com/technicalsupport/product_detail.aspx?product_id=2685
Broderbund... | Answered on Jul 16, 2014
  • The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
    1. Start-->Control Panel-->Add/Remove Programs.
    2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
    3. Follow the panel wizard and reboot your PC when it finished.
    In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
    Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
    A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
    1. Free download Perfect Uninstaller form its official website.
    2. Install Perfect Uninstaller on your computer
    3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
    4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
    It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
    Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
    Under Creative Commons License: Attribution
  • Broderbund... | Answered on Oct 27, 2011
    Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
    Broderbund... | Answered on Aug 18, 2011
    Check to see if the cd is compatible with windows 7. It might not be. If it isn't check the website of the manufactorer to see if they have a download. If they do you can make that download compatible on a windows 7 machine.
    If you have windows 7 professional version you can install xp and then put the disk on the xp part of windows 7.
    Welcome to Fixya. May i ask if you are using the administrator account of your computer? It not can you please try to use it. Please let me know what happen to order to fix the issue.
    Thanks
    Broderbund... | Answered on Apr 28, 2011
    Symantec is foreign for Norton, probably your antivirus software.
    If you've set up a password for Norton is should be that. You need to tell Norton to allow use of your software.
    If you don't use Norton anymore, you need to un-install it properly.
    Broderbund... | Answered on Jan 02, 2011
    Windows 7 Compatibility for Broderbund Calendar Creator version 12 :
    32-bit(compatible) and 64-bit(We are working with the software publisher to confirm this product's compatibility) -->click HERE! to navigate .
    Run the program in compatibility mode:
    1.Right click on the program's shortcut, .exe file, or installation program;
    2.Click on Properties.
    3. Click on the Compatibility tab. (see screenshot below)
    NOTE: If the Compatiblity options are grayed out, then it is a 64 bit program and cannot be changed.
    OR..
    You can use windows xp mode to run calendar creator .
    Please navigate to this page click HERE! and follow microsoft instructions ..
    Please let me know if you need any further assistance.
    Broderbund... | Answered on Dec 29, 2010
    What is the duration of the event that you are specifying? You are sure you are restricting it to just one day? Please give me a little more info here and I can help you out!
    Thanks
    Broderbund... | Answered on Sep 09, 2010
    Lots of information missing here, but at a guess, you have a nasty bug.
    Do a full scan of your system for viruses, rootkits, spyware, and everything else you can think of.
    If you need these tools, check out Gizmos site for a mob of free security software and advice.
    Broderbund... | Answered on Jan 14, 2010
    Hello ccsstjoe,
    Download Revo-Uninstaller, find Calendar Creator 12 in the list of programs and click on it(highlight it). Then from the menu at the top, select 'Uninstall'. On the next screen, select 'Advanced Mode' then Next. After prompting(as directed) through the removal process, reboot your PC and then reinstall CC12. If that doesn't work you may want to return/exchange for something different.
    Broderbund... | Answered on Jul 07, 2009
    try right clicking the icon and run as administrator see if that allows you to work with it, might try setting it to run as adminisrator anways, right click, click properties, and look thru tabs and choose run as administrator...hope this helps...shia
    Broderbund... | Answered on May 22, 2009
    Broderbund Calendar Creator 12 for PC Logo
    38 questions posted
    Top Broderbund Computers & Internet Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Lee Hodgson
    Lee Hodgson
    Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Broderbund Computers & Internet
    Most Popular Question
    will calendar creator 12 work windows 7
    • Computers & Internet
