Do you have WH40 or T104 water heater timer? http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://waterheatertimer.org/images/WH-Off-pin-pushes-lever-400.jpg
http://waterheatertimer.org/images/WH40-water-heater-timer-450.jpg
Normal
0
false
false
false
font-size:10.0pt;
Is WH40 wired correctly?
http://waterheatertimer.org/images/WH40-water-heater-circuit-5.jpg
Is timer working?
If wheel rotates and keeps good time. Then clock motor is good.
Flip manual override on and off >> if manual override is not loose and falling apart then your timer is probably good
ON-OFF Pins:
There are pins attached to yellow dial. Clock motor rotates dial until pins contact mechanical lever. Pins push the lever on-and-off.
Normal
0
false
false
false
font-size:10.0pt;
Two types of pins, ON and OFF:
You need a brass-colored OFF pin to turn off the circuit. You need a silver-colored ON pin to turn on the circuit.
Order more pins:
Your pins may be worn out, or you don't have any OFF pins.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
