Hardware & Accessories Logo
A
Anonymous Posted on Jan 26, 2011
I REQUIRE A TIMER THAT WILL LOOK AFTER 220 VOLTS FOR A SMALL WALL BUILT IN ELECTRIC HEATER SPRING LOADED 30MIN
A
Anonymous
You want spring-operated 30 minute countdown timer for 240Volt electric heater.
You don't say how many watts your heater is.
Answer is longer without knowing watts.
1) As you know, you can turn off any 240Volt circuit by turning OFF one hot leg.
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
People are skeptical when working with 240 V and believe both hot wires have to be turned OFF.
But you know the heater needs both hot wires. Disconnect one hot wire and see.
240V water heater thermostats operate in this way ... they turn OFF 1 hot wire.
2) Intermatic FF30 and FD30 series timers can directly turn off 1 leg of 240Volt 2500 watt heater.
Max 2500 watt, no more.
This Intematic timer is rated for wattage shown. With other brands, check the rating.
Amazon sells FD30 30-minute
http://www.amazon.com/dp/B00004W4WW/ref=sc_vs_google_Intermatic_2520FD3
3) Intermatic also makes DPST timer if you want to turn OFF both hot wires
Aplussupply sells FF and FD Intermatic timers, and 30-minute DPST model FD430M
The rating is same as shown above.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
4) If your wattage is greater than 2500 watts, then you need to install a 30amp contactor with 120Volt coil. Timer turns magnetic coil on-off, coil opens and closes contacts that turn heater on-off. You can use any ordinary light-weight wall timer with a contactor.
http://waterheatertimer.org/Countdown.html
5) Following page gives you information for installing a contactor to handle 240Volt loads up to 5500 watts.
Pages show how to wire, where to buy, what to buy.
http://waterheatertimer.org/How-to-install-water-heater-timer.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Testimonial: "THANKS VERY MUCH THIS IS WHAT I NEEDED TO KNOW. THIS WAS A BIG HELP. STAN"
Electrolux rm2310 3way will only run on gas not on 240 or 12 volts
sounds like ammonia system
ammonia separator uses heat to work on lp gas its a flame
on electric 12 or 220 uses electric heater
small electric heater is probably open
I have an electric estate dryer that does not blow any hot air and continues to run and not shut off???
Greetings,
Unplug the dryer first for safety sake....remove rear cover and use an ohm meter to check the value of your heater and your safty thermostat....this dryer runs on 220 volts, but if only getting 110..it will still run, but heater will not come on....i suggest to check for voltage at terminal block...it should be 220...if not, check breaker or fuses getting back to heater element and thermal...check these and if bad, replace
I have seen the motor switch be bad and the timer as well...both these will cause a no heat problem...bet its the heater thermal or heater
Kenmore dryer runs but no heat. I have ohm checked the heating element, all thermostats and the thermal fuse. All ohm okay. I also checked voltage throughout the circuits from the main block to each...
Did you read ~220 volts AC across the two slanted blades of the power socket? The motor and controls usually run on 115 volts. When the timer is set to dry, press start, and look for ~220 volts at the heater element connections. (Don't let the heater reach full heat if it starts working!) You may have to short the door switch connections to get the unit to run. If you don't read 220 volts at the plug, check the output from each breaker of the dryer pair (should read 115 volts to neutral). Hope this helps!
Oct 09, 2010 • Dryers
Light is on in drum but it won't turn on
You need to verify that there is around 220 volts connected to the dryer with a volt meter. The light only requires 120 volts, but the dryer motor and heater require 220 volts. Also you should go to the electrical panel and locate the breaker for the dryer. It will have 2 switches connected together and should say '30' on it. Try shutting off the switches making sure both are completely in the "OFF" position, then switching them back "ON". A tripped breaker needs to be completely shut off in order to reset. Now test dryer again. Good Luck.
Heating element is not working. Can this be replaced
Heating element can be replaced, however there are several reasons that a heater won't come on. You need to check the electric outlet, breaker, thermostats and the heating element first. Then the timer and motor centrifugal switch. Electric dryers are 220 volts be sure to unplug and be careful what you touch. I hope this will help fix ya.
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
gas or electric ok gas replace gas coils check glow bar ignighter,check thermostates,,,,,,electric check power to both sides of wall outlet you need 220 volts and it will start and timer will advance on 110 vts second check second fuse looks like a thermostate normally located at top of heater coil call if you need to http://www.washerwizzards.com
We bought a maytag electric over built in type, and not to sure if it is a 110 or 220 amps / volts also need information to hook it in
Open the door and look inside near the base of the door. It will say the voltage. Ours is 110. You can go to the maytag website to get an owners manual and installation manual for free.
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if you have a electric meter check the voltage coming out of the wall to be sure it is 220 v???? (meter across black and white)then with your meter only test black wire to ground and white wire to ground seperately you should have 110 from each wire to ground?
If you have only 110 to the black and no reading on the white, you either have a bad breaker or a 110v circuit
If you read 220v and you new heater is rated for 220v black to black and red to white wall thermostat or built in as long as you have 220v to your connection from the wall or your wall thermostat when turned higher than room temp.
Bare grounds tie together and mount to your green ground screw
Re: no heat and timer not moving
  If the timer is set for a auto dry cycle,  the timer won't advance if not heating.  You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
