HLN4365w has three blinking green lights. I replaced the lamp and it still does the same thing.
When i turn the power on I can here the lamp start up with a brief flash on the screen. I then here the relay click and it seems to turn off and it will try to start up again. After the second time this sequence stops. The green lamp light is blinking the whole time. Any help would be appreciated
The projection lamp has not been replaced like 1 1/2 or 2 years and tv on and used like 4 or 5 hours a day on this tv?yes,than the projection lamp life is over.Require a new projection lamp.
Hi, If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy. If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv. You will see 3 seconds long pause between blinks so count pause to pause.
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Well that humming sound is indeed the color wheel, you say you already replaced it.
The thing is that there are two types of color wheels one with a silver bearing and another one with a gold one, for example if your Tv uses a gold bearing colorwheel and you buy a silver one, it's not going to work, if you still have the orginal colorwheel which i think you did since you replaced it last night, just make sure what color the bearing is. Because the color wheel is the one causing the issues on your TV.
