First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Sounds like you have a latency problem. This can be for a variety of reasons, something Cakewalk admits. The reason for that could be everything from processor limitations, not enough RAM, your soundcard, or simply that you need to change the latency configuration in the audio settings menu of the program. Considering that that is the cheapest fix, try changing settings first. Be sure to follor the help information in Cakewalk - they can be a little confusing for Cakewalk (I have no idea why they can't seem to explain their programs after all these years) but you will be able to figure out what settings are right for you.
My guess is that when you record, you are listening to the previously recorded track, and playing to it. Then when you play it all back as a mix, they are not in sync as when you were recording them.
If that is not the problem, plesae explain further. You are able to monitor your previously recorded tracks, right? Not just playing each track "blind" and trying to have them match? Hope not. That is rarely possible - if at all.
If you are monitoring your prerecorded tracks while recording on top of them and it sounds different when you play it back, it's definitely latency.
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
You need tro set up the monitoring capability in your recording software under either hardware profiles or audio settings. All "good" recording software has this monitoring capability. There's another thing - I got rid of my Multimix 8 USB, because it wasn't allowing me to monitor as I recorded new tracks. At first it did, then about a year into using it, this function stopped, and when I investigated further, it was coming up as a single duplex sound card in my hardware profiles in Windows XP. It is as if that functionality of the soundcard component had burned out. Maybe on the circuit board...
I now have a gina Echo that I bought off eBay, and it was the best thing I ever bought. It is a hard card - no latency! Full monitoring! 24 bit recording! A hard card with a breakout box instead of USB! My recordings have never sounded better. The best thing about it is that I sold my ALesis adn was able to by the gina and have money left over - they are out of production (stupidly) and can still be purchased for anywhere between $50.00 - $80.00
You may or may not have a problem with your mixer - check your software settings first. If that isn't the problem, eBay is open 24 hours...
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
