20 Most Recent
M-Audio Fast Track USB (FASTTRACK) Audio Input Questions & Answers
What i/o do i need to hear my tracks through protools
It depends on what version of Protools you are using. And also on what it is running on, PC or MAC. Starting with v9 Protools is hardware independent. Which means and audio interface (I/O) should work just fine for listenning to tracks from protools. Depending on your computer it will support direct audio or core audio. make sure the interface supports ASIO as that is the standard and default way to go
I can record voice, but no guitar. Just as many
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
How do I install the
Because I do not know which aspect of the unit you are trying to install, I have included a link to the user manual which will show you how to install whatever you may need with this unit here:
Click Here
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Why do i hear some
Open up your computer to check usb connection make sure the connection is good and dust free
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
I can record voice, but not guitar. I see the
There is a button on the front that switches between XLR and 1/4" inputs. Make sure that your mic doesn't require phantom power, as the FastTrack doesn't supply the right voltage.
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE
Windows
- OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
- CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
- OS: OS X 10.4.11
- CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE
Windows
- CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
- OS: OS X 10.5.5 or greater
- CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
I am not able to
Pro-Tools 8 and above requires an Intel-based Mac running OS 10.5.5 or later. The newest version you can use with Mac OS 10.4.x is ProTools 7.4, and the oldest version that will work with your hardware is 7.1. The complete system
compatibility list is on the Avid site.
If you meet compatibility requirements, but get an installer error, you may have a corrupted download - try downloading again with no other network traffic from that computer during the download. If I read the download page correctly, most of the downloads are upgrade patches for previously installed versions rather than full installation packages. Attempting to run these without the older version in place will generate some sort of error. - how gracefully it is handled depends on the style, skill and diligence of the programmer.
You may also want to do a file system and permissions check on your computer with Disk Utility to make sure there are none of those problems causing hangups.
Two questions: #1: Fast Track often disconnects.
To alleviate this problem, try moving your M-Audio device a short
distance away from your computer. Another solution is to turn off
Bluetooth and your wireless network and / or airport card during the
recording. If you have a cell phone, move it away from your speakers
and M-Audio interface.
Limited bandwidth of the USB 1.1 bus:
- 2 Inputs and 0 Outputs at 24Bit / 96kHz
- 0 Inputs and 2 Outputs at 24Bit / 96kHz
- 4 Inputs and 2 Outputs at 24Bit / 44.1 or 48kHz
- 2 Inputs and 4 Outputs at 24Bit / 44.1 or 48kHz
- 4 Inputs and 4 Outputs at 16Bit / 44.1 or 48kHz
- 2 Inputs and 8 Outputs at 16Bit / 44.1 or 48kHz (Sonica Theater)
- 4 Inputs and 4 Outputs with every other sample rate up to 16Bit/44.1kHz.
This information applies to recording/playback through separate
physical Inputs and/or Outputs. Of course you can't get more inputs or
outputs than physically present on your USB Audio device. Playing
multiple audio tracks that are mixed down within a software application
and being output through the available physical audio outputs on the
M-Audio USB audio device is always possible (e.g. playing a virtually
unlimited amount of audio tracks within a software application, played
through the outputs 1+2 on the USB audio device). Some M-Audio USB audio
devices do not support all listed Sample Rates and/or Bit Depths (e.g.
MobilePre/FastTrack up to 48kHz, Black Box always at 44.1 kHz).
For USB devices equipped with an power button or switch, power off your
M-Audio device before putting the computer in sleep mode, and wake the
computer from sleep mode before powering your device back on.
For USB devices without a power switch, disconnect the USB cable before
putting the computer in sleep mode, and wake the computer from sleep
mode before reconnecting. You can disconnect the USB cable from either
the M-Audio device or the computer. When disconnecting from the
computer, make sure you reconnect to the same USB port.
If your M-Audio device is not working after following the procedures
above, restart your computer to re-establish a connection with the
device.
