20 Most Recent Steinberg Cubase 4 ( Windows / Macintosh ) for PC, Mac (502012300) Questions & Answers
Here you can get a working code:
Steinberg Creativity First
Steinberg Cubase... | Answered on Jul 03, 2014
ineed seriel no nuendo 5 elicenser activation code
Steinberg Cubase... | Answered on Apr 11, 2013
If you'd like to remove them from your computer you would need to do one of the following 2 things:
1. if they were installed from a disc or .exe you can use the add remove program option from the control panel of your pc...once in their look for the name of either the manufacturer or the plugin name and select remove.
2. If they were installed from simple dragging and dropping of the .dll or folder files then youll need to go to the main plugin location and physically delete the files. In most cases this location can be found in one or more places depending on your operating system:
1. C-->program files--> steinberg -->vstPlugins
or C-->program files-->vstplugins
2. C-->x86-->program files--> steinberg -- vstplugins
or C-->x86-->program files-->vstplugins
Steinberg Cubase... | Answered on Dec 28, 2012
i need nuendo 5 elicenser activation code
Steinberg Cubase... | Answered on Oct 07, 2012
Try to reinstall the applications responsible for the error:
-- It may happen that any program is responsible for the error as one of the main causes is software malfunction. So, reinstall the program by following the below steps:
-- Go to Start-> Control Panel->Add/ Remove Programs -> choose the program that needs to be reinstalled from a given list and click on Uninstall button.
-- Then after, restart the PC in order to refresh the system setting and make a fresh installation of the program.
Replace the Synsoacc.dll existing on the system:
In case of file corruption, you need to replace the file with new one as it can help you in the error resolution. To do this, follow the below steps:
-- At first, connect online and download a fresh file to save in the computer's memory
-- Browse to c:\Windows\System32 to find the existing file on your PC and rename it to synsoaccBACKUP.dll.
-- Now go to Start-Run and type cmd to open the command prompt.
-- There type the command regsvr32 synsoacc.dll to finally replace the file.
Steinberg Cubase... | Answered on Nov 22, 2011
Buy it or read the Terms of Service. We do not help with
"By using the Site, you agree heartily not to do any of the following: Publish on this Site any materials, including questions, comments, suggestions, ideas, plans, notes, drawings, original or creative materials or other information, provided by you either in the form of e-mail or submissions to FixYa, or postings to or on the Site ("Content") that is unlawful [...]"
If you did buy it, then the activation code may be on the box or in the manual.
Steinberg Cubase... | Answered on Jul 18, 2011
chnge the screen resolution to a lower resolution (start - settings - control pannel - display), the you will find the lost window. (after that you can chnge back the resolution again).
Steinberg Cubase... | Answered on Apr 03, 2011
I don't believe your Bose speakers are digital, you need to change your audio settings on the output to analog speakers.
Steinberg Cubase... | Answered on Mar 17, 2011
Dave did you fix it yet..I have same prob
Steinberg Cubase... | Answered on May 20, 2010
you need to render the track. If you push save and select a folder the project is saved to the selected folder. If you render (or export) the track it will be saved as an audio track.
Steinberg Cubase... | Answered on Mar 10, 2010
If you're using the same software on the 32 bit and the 64 bit, that's probably the problem. You could find the right software for your version of Windows if you searched online or at the manufacturer's website.
Steinberg Cubase... | Answered on Dec 03, 2009
Steinberg Cubase 4 ( Windows / Macintosh ) for PC, Mac (502012300) Logo
Popular Tags
52 questions posted
Top Steinberg Computers & Internet Experts
Lawrence Oravetz
 Grubhead
Grubhead
Harrie
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Steinberg Computers & Internet
Most Popular Question
uninstall vst plugins from cubase 4
  • Computers & Internet
