SOURCE: How do you set a tax rate?!?!?
Casio Calc SL-210TE
How to Set Exchange & Tax Rates
Select EX mode
Press AC
Press and Hold for 5 Sec %(Set) key
Press C1 or C2 or C3 or TAX+
Enter New Rate
Press %(Set) Key
New Rate is now Saved
Hope this Helps ..Mike
SOURCE: Set Tax Rate
Type in the rate of tax you want to use, then press rate and then press tax+ :)
SOURCE: how to set the tax rate
Its easy just type in the tax rate that you want, then hit the rate button. Afterwards leave tax+ pressed and you should see the tax % sign appear above the number you punched in, and THATS IT!!! Easy!!!
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
