Tell us what happens when you reset the L1 with the C, Exp. Mode(Far left key), C, Exp. Mode, 14, then Print clearing method. Do this reset procedure then lift up the ADF and watch with scanner move back and forth. It should bump out and in a few times with the lamp lit. Then park back into home position.
That is the cause of your L1. There is a white reference strip under the glass where the scanner "bumps" out. It is suppose to turn on the scan lamp and reflect it off this strip so the machine can get an exposure reference. Since the lamp is not coming on the machine is assuming that the scanner is not moving. You either have a bad scan lamp or possibly a bad lamp driver board. This Is the small board located at the rear left side under the glass.
I will take a look on Momday when I return to work.
Thank You
scanner only bumps out and back in ONCE, then L 1 appears
scanner bumps out and in ONLY ONCE then L 1 flashes
Don't notice a lit lamp
