The Z650 is designed to work with SD cards. Your 8GB card is actually an SDHC (Secure Digital High Capacity) card. While an SDHC card will fit into an SD slot, it will not work properly. You'll have to stay with SD cards 2GB and smaller.
2GB is all your Z650 will take , I have the same model I have had the Z650 for about four years now
SOURCE: Can't format 8 GB SD memory card
The camera doesn't support this memory card.
Memory card support : SD/MMC up to 2 Gigabyte only.
Sorry you will have to downsize.... :)
If helpful pls. rate me and/or recommend me TXS
SOURCE: My Kodak P850 do not accept SD cards 4 or 8GB,
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
