DHD NTX-2004 Car Audio Amplifier Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How conect one subwofeer 12 - DHD NTX-2004 Car Audio Amplifier
Level 3:
  • DHD Master 17,130 Answers
  • Posted on Aug 11, 2010
DHD Master
Level 3:
Answers
17130
Questions
0
Helped
3635789
Points
52372
The sub woofer can be connected by bridging one side of the right channel to the other side of the left channel. Usually this will be marked on the speaker connection terminal and use will not have any trouble to locate. If not use the + ve of the right and the - ve of the left to connect to the sub woofer. turn it on and check . If you find the phase different- with less bass- reverse the connection and try. this will work fine. Good day
WHAT IS PROBLEM WITH MY YAMAHA?
Turn the power amplifiers off first and on last. Your problem will go away.
Dv7 subwofer is missing so speakers and headphones dont work. Do i need a new subwofer?
Generally speaking, sub-woofers are not built into notebook computers, as most sub-woofers would not fit. However, there are generally speakers, and there tend to be problems with the audio drivers in most cases if there is no sound for both speakers and headphones.
Within the notebook, there should only be two speakers. If they're missing, did you buy this used or refurbished? If someone just yanked out the two speakers and carelessly cut or handled the wiring improperly, then this could interrupt the headphone bypass cut-off.
I know you mentioned you'd already verified everything appeared to be working properly, and in some cases updating drivers or uninstalling and re-installing them has a positive result. For the obvious, which I've also forgotten to check sometimes, is whether the output is muted within the volume control and mixer.
In case you hadn't already checked out these, here are a few links you may find useful:http://h10032.www1.hp.com/ctg/Manual/c01613382.pdf
http://h10032.www1.hp.com/ctg/Manual/c01613127.pdf
As always, the more complete the information up front, the better the potential for a solution. I hope this helps!
How install orion 600d to kiker 12sl5 subwofeer
Look up your question on youtube. Honestly it will help clear things up a lot. Don't worry about the exact subwoofer your connecting it to. But type in "how to connect orion 600d amp to a 12 subwoofer(s)
12" trouble shoot
the rca conection might be grounded or perhaps damaged, why not replacing the rca thats conected to the sub to the amplifier, i had that problem before and when i replaced the rca(usually its a y-form) it worked perfectly
Blown subwofer?
I believe what you have now is known as a subwoefer. Toss it.
My pair comuter speakers work, and there pluged in right, but don't pay anything out of them.
I assume you have told Windows about you new speakers ???
(Start, Settings, Control Panel, Sounds and Audio Devices = Volume tab, Speaker Settings box, Advanced button ...)
Computer speakers
Hello Yodybear
First, have to see if all cables conection are fine, 2) check each speakers, to see if all speakers work. 3) use the upmix to 5.1 or 6.1 and see if work, and of course, if your subwofer has this swith or feature.
good luck
Top DHD Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
