Test for voltage going to the treadmill, if there is no power going to the treadmill then check the fuse or breaker in your house. If you already checked the house fuse/breaker then try this.
first thing is check for any loose connections or bad wiring and then follow the steps below to try and determine what is wrong with your treadmill.
* Check the breaker on your treadmill it can be combined with the on/off switch or it can be a separate breaker. Make sure it is not open.
* If that tests ok, check to see if your getting power to the motor controller(electronic board under the hood) this can be done by following the power cord in and testing where they attach, if you are getting 120/240 volts then check the light(s) on the controller If they are not lit then the controller is bad.
* If they are lit you will need to check the dc voltage going to the motor
* Also make sure you have voltage going to the console
if you have 8-12 vdc voltage to the console and the console is dead replace the upper control board.
* If only one or none of these voltages are present then the controller is bad.
* If your treadmill is equipped with a separate power board then you will need to take voltage readings going in and coming out from the board If nothing is present then the power board is bad. If all tests well move on to the controller.
* some motor controllers are equipped with a fuse on it, if this is blown the console will not light as well.
* Hopefully it is just a breaker.
* Make sure you are lubricating your treadmill as well on a regular basis. Too much friction can wear out electronic parts and reduce the life of your treadmill. Use the appropriate lubricant recommended for your specific model and never use an extension cord.
Thank you for the question and please feel free to contact me again with any questions or problems you may have.
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
