Samsung Compact MiniDV Digital Camcorder Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Problem with my Samsung VP-D351 Pal. When the LCD is in normal mode it is blurry but in nite pix its fine. Please help...
Duane Wong
Level 3:
  • Master 6,826 Answers
  • Posted on Jul 24, 2010
Duane Wong
Master
Level 3:
Answers
6826
Questions
6
Helped
2862187
Points
20234
Http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=VPD351&searchInputBox=VP-D351&find_button=
when vp-d351 is input, I get two downloads one for software and one for a driver.
I could not locate the instruction manual.
You could contact Samsung to talk to them about this problem:
http://www.samsung.com/us/info/contactus.html
Have a samsung mini dv digital-cam VP-D351 PAL and im trying to connected it to the computer but its not being recognised by the laptop. Thank you for any information that you can give
Have you installed samsung VP-D351 driver in your computer? If the driver already been installed, it may crashed and need new installation. If you had not istalled it before, you have to install it before pairing them.
The CD driver usually bundled in new VP-D351 package together with owner manual and service centre address.
VP-D351 need to connect with TV. What type of cable is required
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
6helpful
2answers
Model number vp-d351
i had same problem, solved it with replacing the lcd fpc lead (ribbon).this is the lead to the screen.it breaks after about three years.this is a common fault.. replacement part from Partmaster.co.uk or 0870 240 6603..part number..SAMAD9706489A. cost £11.40.. its easy to replace ..takes a little time.. i have emailed instructions to two others and they have sucessfully completer the task.. if i can help with instructions,please ask.. i have also purchaced a second ribbon for next time..(3 years time )..good luck stefan.
2answers
I have a samsung mini dv digital-cam VP-D351 PAL and im trying to connected it to the computer but its not being recognised by the laptop. Thank you for any information that you can give me.....
If you are running windows vista this will be the problem.There are no drivers for vista firewire..If other windows then try samsung support for required driver.
3helpful
No Display On LCD in VP-D351 Samsung camcorder
hi ..had the same problem..had advice from this site two weeks ago..which was spot on..the lcd screen ribon has brocken.. its available from partmaster..www.partmaster.co.uk...part required..no SAMAD9706489A..£11.49.. took me half hour to take camera apart (carefull.y) 10 min to put back togerther.. works brilliantly.. good luck.. Need futher help email me..stefjanet @yahoo.co.uk..
2helpful
Samsung vp-d351
you have 2 differnet problems. white screen is a bad ribbon cable inside unit.. eject r is a bad tape transport. something broke inside or the tape transport is outta alignment.
Samsung VP-D351/XEU MiniDV Camcorder screen does not work all the time
the camera doesn't record colour in normal mode, but night mode works perfectly...any ideas what I can do to fix it, the focus isn't great in normal camera mode either...thanks
May 18, 2008 • Cameras
1helpful
2answers
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
