First off how long have you owned the camera? It sounds like damage to the recording head has been done. This can only be repaired by a qualified professional. Follow this link to start the repair process through canon. You may also try other independent professionals if you prefer.
https://www.usa.canon.com/consumer/controller?act=OnlineRepairBookingAct
Thank you and good luck,
Lee
It sounds like the tape itself is damaged. Get an head cleaner cassett and clean the mechanism. This will clean the wheels and heads that tape runs over. Also try a new tape cassett to see what happens and listen to the camcorder for any crunching sounds as this would suggest that something has broken inside the camcorder.
Good luck.
I have tried all different tapes. All the tapes that i had recorded on the previous night and had played back fine on the camera just prior to the "incident" are all behaving the same way. They have content but the camera think they are blank and playback does not show anything.
I know the tape head cannot be dirty because i have used it very lightly - total recording time since i bought probably is not more than 10 hours.
When the tape got chewed there is a possibility that a wire has become disconnected from the main head unit causing the camcorder not to read the tapes.
Eject any tape and take a close look at the head unit, see if any wires have become dislodged.
Okay - I will check it once i get back home in the evening. But just to let you know how the crunching happened -
1. The tape was playing.
2. I ejected the tape without pushing stop. I think that left the drive capstans still rolling.
3. I took out the old tape and put in a new one (while the drive mechanism is still rolling - shouldn't they have a built in mechanism to stop the drive mechanism when the tape is ejected ? )
4. I closed the door and that is when the crunshing happened.
But please note that afterwards the camcorder was working just fine until i tried to wrestle in the now crunched tape the second time.
I also been googling about it and found something about head alignment. Any idea if that is what happened ? and how to fix ?
When the tape is ejected the drive mechanism should drop down and the door released. If one of the pins that grabs the tape and runs it over the head unit has gotten caught this could be the problem.
Head alignment can also be factor like you have mentioned but then the camcorder has to be taken apart (especially the door) so you can see just whats happening when the tape is loaded.
They can be fixed but they have to be taken to a specialist to either realign the head unit, rewire any loose or broken connections and to check the tape grab arms.
Another possibility is that the mechanism has jammed but this won't be determined until the door is taken off the camcorder.
Hi
I checked and there are no dislodged wires or anything. Everything looks okay. When i close the door, the mechanism engages and pulls the tape down to the head and then it starts rolling - but no picture. Now what ?
Do you get any picture at all? for example snowy picture or just a plain black screen?
I get just the blue screen. the tape position indicator changes showing the minutes left but the tape counter above it just displays dashes - as if there is no data on the tapes.
No picture.
In camera mode - I can see the image that i am shooting. It says RECORDING but when i rewind and playback - again no picture and the counter keeps showing dashes.
This is usually caused by a failed component in the power circuit within the camera. This will require disassembly and trouble-shooting to identify and replace the defective component and can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
During playback, I get just the blue screen. The tape position indicator changes showing the minutes left but the tape counter above it just displays dashes - as if there is no data on the tapes.
No picture.
