If you haven't changed the motherboard from the time you bought it, then there must four onboard sata connectors on the motherboard, refer below picture;
If you haven't installed four sata drives, then there must be at least 3, you can connect the new hard drive on any port, no matter Master or Slave, Primary or Secondary, it'll automatically set it for you. You also no need to worry about the cable, both the ends are same, it works on any directioni need help installing a second seagate 1tb - 80e9306.jpg"/uploads/images/80e9306.jpg" alt="80e9306.jpg" class="h_mi" />
Same thing with the poi need help installing a second seagate 1tb - daeb671.jpgyou can join it on any power cable..
I hope this helps, if you have problem with this or if in case your motherboard is different, please let me know;
Good luck.
Thanks for using FixYa.
