GE profile bottom freezer frig stopped cooling...the indicaters in the frig that had displayed temps for frig and freezer went blank...unit about 6 yrs old. Any ideas
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
SOURCE: My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
SOURCE: our GE profile freezer/frig - frig side has ice on coils
The profile uses a motherboard instead of a defrost timer. you can remove the evaporator cover and you will see a glass defrost heater at the bottom and a white sensor and a defrost thermostat at the top of the coil. you can ohm out the thermostat and the heater. If the white sensors have a round end instead of a flat end replace any way.
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
