20 Most Recent GE GBS18KBM Bottom Freezer Refrigerator Questions & Answers
did either of the repairmen check the defrost heater, sounds like that may be your issue.
GE GBS18KBM... | Answered on Mar 07, 2016
This is a clogged defrost drain, this unit its fairly difficult to clean and get to, its either clogged with ice or debris but i would recommend service unless you are fairly used to repairing appliances and such.
Sean
GE GBS18KBM... | Answered on Mar 28, 2011
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
GE GBS18KBM... | Answered on Aug 28, 2010
defrosted around fan between freezer and fridge. works fine now
GE GBS18KBM... | Answered on May 03, 2010
May be a fan motor problem on the condenser. if no airflow over condenser your unit will just pump hot gas round the system. which means no sub cooling of the gas before it reaches the expansion device ( ie: capilliary tube in your case. Try a little WD 40 on the fan axle.
GE GBS18KBM... | Answered on Apr 18, 2010
Ordered new replacement parts online
GE GBS18KBM... | Answered on Jan 03, 2010
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
GE GBS18KBM... | Answered on Jul 23, 2009
It does sound like the normal defrost cycle. Aslong as it stays at an average below 12 degrees it is normally working fine. Check to make sure the back air vents and front grille are clean and the fan by the compressor is running when the unit is on. It has to get rid of the heat so it will freeze.
GE GBS18KBM... | Answered on May 16, 2008
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
GE Refrigerators | Answered 3 days ago
GE GBS18KBM Bottom Freezer Refrigerator Logo
Popular Tags
12 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
bottom freezer works good but top
  • Refrigerators
