Just purchased 1999 Harley Davidson ultra classic. The brake lights, turn signal and horn not working.Everything else( running lights etc... are ok) Checked fuse... seems ok.What else can be the problem?
Re: Brake lights,turn signal and horn not working...
Check the wiring within the headlight shell--look for connectors that may be corroded or pulled loose. A little WD-40 will favor connection integrity when sprayed into the connectors, then coupling and uncoupling them several times. Hope this helps!
Probably the switch inside the brake lever. They're touchy and you have to be very careful or you'll be buying a new one again. You Tube they'll show ya.
First you check that the left turn signal and brake switch wiring haven't been switched. I presume brakes and turn indicators use different bulbs. Then you check for shorted wires from wear or crushing where they go from headlight
chk backwards to your turn signal control unit. The brake lights and rurn signals are routed in a way that would affect each other.Is this a four wire or?Chk fuses 1st. Good Luck- -Ned- A good grd is important.
