Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
