20 Most Recent Behringer C1U Microphone Questions & Answers
I'm having the same problem, however I can say that Phantom Power is out of the question. the c-1u is a variation of the c-1. The difference is that the u doesnt require phantom power
Behringer C1U... | Answered on Oct 09, 2018
These microphones need a Phantom power supply to operate. This power supply gives 48 volts to the microphone in order to make it work.
Behringer C1U... | Answered on Feb 02, 2018
Did you install the mic's drivers before plugging the mic in? Have you tried it on 32bit operating systems other than Win 7? I don't think it will be an audio driver problem ie: asio4all. But because the OS doesn't recognise the driver automatically it might indicate where the problem lies. I am not familiar with this particular mic ( I use AKG cs1000s with Zoom R16 audio interface ) but I know there can be issues with some 64 bit systems and certain audio hardware. Nothing in the Behringer forums?
Behringer C1U... | Answered on Aug 21, 2014
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Behringer C1U... | Answered on Apr 02, 2014
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
Behringer C1U... | Answered on Oct 20, 2013
You will need to turn on the phantom power which will be a switch labled eithe PHANTOM or +48V to use the condenser mic. YOu MUST use an XLR to XLR cable.
Behringer C1U... | Answered on Feb 26, 2012
Answer from official Behringer support:
The green LED is fine. The newer units have green LEDs.
Please download and install asio 4 all from:
http://www.behringer.com/EN/Products/C-1U.aspx
We hope that we have been able to help you with this information.
Behringer C1U... | Answered on Feb 19, 2011
I doubt that there is a problem with the unit. Usually people have problems with their cables or the speakon plugs themselves.
Unscrew the connector that is used on both ends and double-check their connections. Sometimes the screws that hold the heavy gauge wire in place, come loose. Also make sure that they are in the right places. Sometimes you have 4 connections. Make sure they are in +1 and -1 connections. Every once in a while you'll find a quirk unit that requires you to use +2 and -2 instead. Look at the back of the amp. It should tell you which numbers it uses. Make sure you check the same thing on the speaker end also. If you have a meter or continuity checker, use it to make sure it's wired right.
This is a professional piece of equipment. They don't go bad easily. Make sure you tighten those connections real good and that you pay close attention to the engraved numbers on the speakon connectors. (That is if they are quality connectors. The cheap ones may NOT tell you the numbering or the phase, ((+ or -)). Hint: The negative one is always closest to the outside of the plug. You'll have to study it to understand that. The screw terminals on the inside have 'walls' on both sides of it. Those are the + connections.
Also, check the switches on the front. You may have one of the switches in the wrong position or setting. Also if you're using phantom powered mics, you have to turn the phantom power on or else they will not work. Hope this helps.
Behringer Audio... | Answered on Oct 05, 2019
Do you have the mics and dongle system accessories? Your question does not state if you have them or not. If you do have these accessories, and you only want to use the wired option, remove the dongle so it stops searching for the microphones.
Hope this helps.
Behringer Audio... | Answered on Jun 27, 2019
Behringer C1U Microphone Logo
19 questions posted
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Behringer Audio Players & Recorders
Most Popular Question
mic behringer
  • Audio Players & Recorders
