2004 GMC Envoy Logo
Posted on May 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Igniton key is stuck in switch and won't turn off
The key won't turn to to the off / remove position. It runs the battery down. Also the transmission shifter won't lock into position. It moves from Park to Low without stopping. The doors locks will open in Park position, but the key won't turn off or come out. The vehicle is a 2005 GMC Envoy SLT with apporximately 60,000. First time any problem with no problems until now.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
3953
Points
44
Had/have same problem.....charge battery.... if aftermarket alarm,, turn off....(lock unlock with key fob) then should work.
Jonah Oneal
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • GMC Master 14,092 Answers
  • Posted on May 16, 2010
Jonah Oneal
GMC Master
Level 3:
Answers
14092
Questions
0
Helped
7241993
Points
44533
SOUND LIKE PROBLEM IN THE SHIFT LOCK CONTROL SOLENOID.BUT FIRST CHECK BRAKE LIGHT SWITCH AND FUSE.AND IF YOUR BATTERY WEAK DONT HAVE AT LEAST 12.5 VOLTS.WHEN YOU DEPRESS BRAKE PEDAL NO POWER TO PARK LOCK SOLENOID.IT WONT ALLOW YOU TO REMOVE KEY FROM SWITCH.PRESS BRAKE PEDAL TO SEE IF BRAKE LIGHTS WORK.IF NO.IF FUSE GOOD SWITCH IS BAD.BUT YOUR BATTERY HAS TO 12.5 VOLTS.IF BATTERY VOLTS GOOD AND BRAKE LIGHTS SWITCH AND FUSE GOOD AND THE PARK LOCK CONTROL SOLENOID FUSE IS GOOD.THE PARK LOCK CONTROL SOLENOID BAD.YOU COULD ALSO HAVE A FAULTY KEYLOCK CYLINDER.
Ronny Bennett Sr.
Level 3:
  • GMC Master 6,988 Answers
Ronny Bennett Sr.
GMC Master
Level 3:
Answers
6988
Questions
Helped
2287730
Points
21993
Check the shift cable to the shifter to the transmission,and the shifter could be malfunctioning.
Igniton cylinder lock
The shifter control for the transmission is probably worn, so the connection to the electronic control switch is not making contact to be able to release the key,if your shift handle is loose from pushing and pulling, that may be the problem.
1helpful
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
1helpful
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
Ignition switch will not turn off aux position, key turns to on position but will not turn on or anything off, had to disconnect the battery, please help?
your igniton key cylinder is worn or broken or need new parts and check ignition switch also does this have tilt steering could be a bent rod connects igniton switch to ignition key clyinder (where you put your key in and turn)hope this helps
Key stuck in my 2006 Buick Lacrosse I can start and drive the car but can't remove the key after turning off the engine without pushing the release button which is at the bottom of the steering colum. I do...
bad battery and if i don't drive the car couple of days then it goes dead ??? It's not the battery , you have a parasitic draw on the electrical system , that is what is draining the battery . Could be the instrument cluster .Watch this video . What's giving out 13 volts or when ? With the engine running hooking a volt meter to the battery the voltage should be 13 - 14 volts , depending on the load on the electrical system.
Chevrolet Truck Battery Dies Overnight Part
Does the vehicle have column or floor mounted gear selector ? Both have a safety feature Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator:
Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator: If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The column ignition lock system consists of an ignition lock cylinder control actuator, and a park position switch that is located in the automatic transmission shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
Linear Shift Assembly: If the vehicle is equipped with a column mounted gear shift, it has a linear shift assembly on the steering column. The linear shift assembly has a cable that runs from the linear shift assembly to the ignition lock cylinder case. The purpose of this cable is to prevent the ignition key from being turned to the OFF position when the transmission is in gear and the vehicle may still be moving. The linear shift assembly cable contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
3helpful
3answers
Ignition is stuck in run position
does your key stays in the ignition position? or can you turn it back to acc or lock? it might be a stuck ignition switch mechanism inside or a shorted circuit that latches the ignition...have it checked or you can try to open it the switch yourself..but with caution if this is your first time. Pls give me a feedback. thanks!
Iginition key Stuck in on position
the igniton cycinder has failed, have a lock smith remove same and reprogramme a new key
New ignition switch now car security system locked
ok here you go
make sure the battery is fully charged befor starting
turn ignition to run
attempt to start once then release the key in the run position
let vehicle sit with the key on for ten minutes
the security light should turn off
turn igniton switch off
wait 5 seconds
turn key to run position
let vehicle sit for 10 minutes
turn key off
wait 5 seconds
let vehicle sit for ten minutes
turn key off
wait more than 6 seconds
and start engine
1helpful
Key gets stuck in 97 chevy blazer
It sounds like your ignition switch is shot. Not the key and tumbler, but the actual switch which is down on the bottom of your steering column, and connected to your key and tumbler by a rod.
Ignition
i just had that same prob with mine. My Solution: NEW steering collum / key switch
what was happening was the key would get stuck in the igniton and i had to give it a little tap to get it to relese from the igniton. well, by giving it those taps, it popped a little plastic lever in the collum for the igniton switch. then the car would turn on with the key, but not turn off, i had to do the same thing that you had to do to to turn it off/on.
A steering collum later, and it was fixed
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
