To stop the motor, the mains has to be switched off. Sometimes when emptying the bath, the motor will switch off normally.
The non return valve that is installed at the lip of the outlet from the unit has been jammed open. Usually it gets jammed with residue and or a build up of sludge. This permits a backflow of the pumped water back into the unit. It pumps it again and within a few seconds the waste/water flows back into the unit. Open it up (the outlet pipe) and clean it making sure the non return valve (it is a rubber hinged cap) moves freely.
See diagram here (last page of PDF):
Saniplus repair instructions
Climatizarea nu functioneaza in sensul ca nu am aer rece ci doar aer cald
