Whirlpool gold side by side GD5SHAXMT
Water is still flowing to front door access....water for a glass.
red light is flasking in infrared reciever...is that right?
I want you to try the ice maker by filling with tap water and let freeze with ice maker left on. If the cubes drop into ice bin the the side of the dual water control valve for water feeding ice maker is defective. Let me know your results, Thanks, Sea Breeze
Click Here=> 4389177 for dual water control valve.
Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
The red light should flash, the most likely suspect is that the inlet
tube that carries the water to the ice maker is frozen. If you open the
freezer door and hold the swinging door in front of the ice maker up you
will see a black rubber tube coming down from the top. If it feels hard
it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or
unplug it, warm up the tube with a hair dryer or for quicker unthawing
take a turkey baster and squirt hot water into the tube catching the run
off with a towel.
It can take quite some time and several cups of hot water to finally
clear the ice. Once done it will take about 2 hours for the ice maker to
cool back down and start a cycle to test it.
