I had culligan check water softener, and it is ok. Culligan guy recommended against jet dry product, which I have been using. Have not changed detergent in a while, but problem just appeared suddenly. Water is definitely hot enough.
I am trying a cup of vinegar in an empty load right now to see how that works.
Any recommended/preferred detergent products?
Thanks
JDB1095AWS dishwasher with stainless interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
