On opening up the drive I found that the wide flat, red lead connection was loose/broken. On unplugging it I found the copper connections wee lose/bnroken/ missing. Can I get a replacement so that I can check if the drive will start and work long enough to allow me to copy off the data ?
Any 3.5" hard drive (sata) enclosure off of ebay will work. Shouldn't be more than $20. If you want somebody else to do it for
you there is Hard Drive Repair NYC.
1. the usb connector in the PC may have a broken board contact needs soldering or replacement. 2. there may be a broken USB cord to the external usb drive 3. the electronic controller in the USB case may not be working. 4. A new case may be needed with a new controller.
Yikes 500 GB is a lot of data to lose, especially if you have no back-ups. In case you have never seen the inside of one, a hard drive is a series of metallic/magnetized platters on a spindle and a series of arms (resembling those of a record player) for each platter which record and retrieve data in the storage sectors formatted on the drive platters. The top 3 enemies of hard drives are: Impacts - Heat - Magnetic Objects . . . these top 3 all prove fatal to your drives operation. I am guessing the impact from when you dropped your HDD jarred the arms from their position or even may have broken the reader head. The bigger the storage of the drive, the more fragile they seem to be. Once an arm is dislodged or broken, the drive cannot function... the damage is mechanical. An arm knocked from its point of origin when not in use or jarred durring data access can no longer properly know where data is or fins its original position. Dont waste time on file recovery programs if this is the case, they require an operational drive to scan leftover data. . if the damage is to one of the platters, you might have luck with a software recovery application, but the process is very very slow and will take days. You can try taking it to data recovery experts and it will cost you usually around $1.00-5.00 per gigabyte - pretty costly. My advice, See if you can RMA the drive if it was under warranty) to get a new drive . . . or even have the data retrieved if it was that important . . . other than that, move on and be more careful with external drives in the future. Look for drives that have good impact ratings if you have a propensity for clumsiness, even then, handle with care.
LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Disque dur Je un ne sais pas exactement ce que vous faites référence en ce qui concerne la fonctionnalités de votre Lacie avec votre Mac, comme je l'aurais plus besoin de détails de vous. Mais, au moins à vous diriger dans la bonne direction.
Si
vous avez besoin davantage d'aide, laissez-nous savoir si ces liens de
soutien ne permet pas de résoudre votre problème actuel avec LaCie. également fournir des précisions sur la question, afin que nous puissions mieux vous aider.
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
If the cable is not permanently attached to your drive, you can easily replace the cable for very little money. I am not sure about in Norway, but right here in the U.S., we can run down to Big Lots to buy a new cable for like $4.00. But be sure you get the right cable. The are four different kind of USB connectors commonly used for PC accessories.
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
