Since both ends of each vacuum line is important, it is imperative that you connect the correct line to the correct ports. A Chilton's manual for your vehicle will contain a vacuum diagram. Generally in today's cars these look a lot like someone threw a plate of spagetti on a picture of the engine; but with patience and not getting frustrated, you should find exactly where those disconnected lines should go.
More than once I personally have had to remove all the vacuum lines and start from the beginning to get them all back in place. This is one reason your mechanic gets 'the big bucks'.. Good luck.
It means your battery is bad or its the wrong battery so if you've had the same battery the whole time you need a new one. If you just replaced it then its the wrong battery.
It might sound absurd but the frantic truth is that the LCD screen of your phone is bad which might be as a result of previous shocks and abrasions which it has been subjected to.This is a common feature of the 9700 bold.
The only solution is to replace the LCD screen of your phone,it cots between 40-79 dollars .
Your Blackberry just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry 9700. Download the Blackberry Desktop manager and run the
application loader.
I recommend you correct your phones behavior by replacing its firmware and system software. The latest BlackBerry Bold 9700 system software is available through here.
Replace the system software of your BlackBerry Bold 9700 to correct your locking up issue. The latest BlackBerry Bold 9700 system software is available through here.
Have you fully charged the battery before trying to use the phone?
