Question about RIM BlackBerry Bold 9700 Smartphone
Blackberry 9700 sms some get locked up and i have to reset with battery pull out
Posted by vijayrathina on
Paul Sager
  • 2,335 Answers
Replace the system software of your BlackBerry Bold 9700 to correct your locking up issue. The latest BlackBerry Bold 9700 system software is available through here.
Posted on Mar 22, 2010
HOW DO I RESET MY BLACKBERRY 9770 BOLD BACK TO DEFAULT FACTORY SETTINGS
To reset the Blackberry Bold 9000 / 9700 with three methods. In the first method you hold down the Alt key, the Caps lock key and hit Delete. Your Blackberry will start resetting. This process will take about 2 minutes to complete. The second method is the double reset. Hold down the Alt key, the Caps lock key and hit Delete twice. This method is helpful if your Blackberry is frozen. The third method is called the battery pull method. Remove the battery and keep it out for about 30 seconds and then put it back and power on. It will reset in 2 to 3 minutes. You resort to this method if the first two methods don't work.
Nov 05, 2014 | Cell Phones
Its locked
If it is locked to network,you can unlock it easily using unlock code.Visit the site Unbblock.com
get unlock code at low cost and unlock Blackberry BOLD 9700.
Aug 24, 2013 | RIM BlackBerry Bold 9700 Smartphone
Blackberry Bold running latest software, have the most recent blackberry desktop software. JVM ERROR 545 appears when turn the phone on asks me to reset, reset many times, battery pulled, nothing works....
Well you can again upgrade the 9700 software from here
http://senseapplied.com/index.php/upgrading-blackberry-9700-and-9300-to-firmware-6-0-0-448/
If you like the solution do give us all thumbs up
Farhan
May 21, 2011 | RIM BlackBerry Bold 9700 Smartphone
My Blackberry Bold 9700 seems to use messenger screen for sms's. After every line I hit the enter key: it sends an sms.
it could be because you have the "press enter key to send" option set to yes. go to options, then go to sms. then you will see the option press enter key to send, set it to no so you wont send sms when pressing the enter key.
hope this helps.
May 14, 2010 | RIM BlackBerry Bold 9700 Smartphone
Can't send or receive sms from my blackberry bold 9700
High there,
You need to determin if the SMS icon is hidden first.
Main menu > BB menu key > Show all.
If this is not the case you need to look into the message folder, found within your email icon and view folders. If SMS is missing then a handset wipe will be required.
Common issue on 9700
Apr 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
Can't get SMS messages for the passed few days.
Have you tried the SIM in another handset? Have you reset the handset to default (carrier) settings? If outbound SMS does not work even in another handset, it is more than likely an incorrect routing table entry on your providers end. I had a similar issue where I could not be contacted from one certain network after a number port to a different carrier. The old carrier missed the routing table entry and all my calls from the network were being directed to the wrong IP/Destination.
Mar 15, 2010 | RIM BlackBerry Bold 9700 Smartphone
I bought blackbary 9700 from dubai i have problem
Many quirky behaviors for these devices are fixed every time a new software version is released. You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
Mar 09, 2010 | RIM BlackBerry Bold 9700 Smartphone
Home screen shows i have 1 unread sms or mms and I dont
Try removing and reseating the battery to reset the device. It should also reset your messages count once it connects to your provider.
Jan 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
RIM BlackBerry Bold 9700 Smartphone Logo
766 people viewed this question
Top RIM Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Marvin
Marvin
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
