Broderbund American Greetings Creatacard Platinum 8 for PC Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is Broderbund Creatacard compatible with Vista?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Apr 05, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557683
Points
31058
In Vista, start the "Windows Program Compatibility Wizard".
Choose to install a "Windows XP" program, namely the Broderbund software. Vista will wrap a "cocoon" around the application, to fool the application into thinking that it is running under Windows XP, not Vista.
Is there a Creatacard CD compatible for Windows 7?
Creatacard cannot be run under Windows 7 because of compatibility issues. You have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Why am I unable to install my existing CreataCard Gold 5 on my Windows/Vsta? Can you please advise me?.
There are unfortunately a few older programs that are not compatible with Vista. Check on the box it will tell somewhere on it what Operating Systems it works with.
I am running Windows XP had a virus peoblem had to have pc wiped now I'm unable to re install creatacard Gold. Any answers please
Hi there
Which version of the product do you use an do you use windows vista ?
For compatibility for windows vista you can check the program here :
http://www.microsoft.com/windows/compatibility/
It does not work with version 7 of the creatacard Gold., you can see it here :http://www.microsoft.com/windows/compatibility/Search.aspx?type=Software&s=creatacard%20Gold&page=1
You can try to right click on the icon of the installed program and choise properties and then choise the compatibitility tab and then choose compatibility with with windows xp instead.
You can also choose to upgrade to a newer version on the product homepage here :
http://www.encoreusa.com/default.aspx
OR
http://www.broderbund.com/store/broder/DisplayHomePage
I am not sure of which of the sites are the default homepage
hope that helps
Have a nice weekend :O)
Please rate my answer
CreatACard Platinum 7 won't install on Vista Home Premium
If this is a new install from a new purchase, always give the manufacturer a call because they should know what it is compatable with and walk you thru most common problems.
I am trying to install creatacard 8 on windows xp home. it freezes at 8% installing fonts. i have installed this before on my computer and this time it does not work.
I have the same problem when trying to install on Vista (Home version), except it freezes at 4% intalling fonts. Have tried to adjust setup.exe properties to compatible options, still doesn't work. Also used Windows Vista compatability wizard with no luck.
1helpful
I am getting a laptop computer. I have CreataCard Platinum 8
Vista has been a problem since it was introduced. Essentially Microsoft released it without ensureing driver were available for existing software and hardware. Some manufacturers have been making efforts to get Vista compatible Drivers available. Check the software websites for updated drivers.
Every time i try to load a calander it comes up with a c++ error
The SmartDownload version is not compatible with Microsoft Vista. Check system requirements for Vista compatibility before purchasing the CD version.
3helpful
Creatacard Platinmum 6 won't work with Windows Vista.
CreataCard Platinum 6 is designed to be used with Windows 95/98/2000/Me or NT 4 and XP, therefore in order to run it in Vista I'd suggest to run your program using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> Properties-->Compatibility--> select one of the versions above
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
