My 23 inch technika tv/DVD combo model no: x23/50c-bt-ftcd-uk is displaying source lock on the screen and I don't no the codeMy 23 inch technika tv/DVD combo model no: x23/50c-bt-ftcd-uk is displaying source lock on the screen and I don't no the code
AnonymousMar 16, 2014
You can't post conmments that contain an email address.
Remove any DVD from the player At the blue screen type 9735 (DONT press setup like other website will tell you to do) A menu should pop up. select region then select region 0. (0 = muli-region) Select exit setup Power off the TV
Iv just done this so i know it works
Remove any DVD from the playerAt the blue screen type 9735 (DONT press setup like other website will tell you to do)A menu should pop up. select region then select region 0. (0 = muli-region)Select exit setup Power off the TV
hi,
First of you have to check the Atenna connection in the rare of your tv. Check for any loose contact on the connection of the wire to the pin. may be its the cause for showing signal as 0%. you can confirm the same by connecting the tv at the place where you doughters tv is connected. If there you get the picture then there is some thing wrong with the atenna connection.
If want information how to tune your tv then need information like BRAND and MODEL NUMBER of you TV.
ok
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Suddenly my DVD player has stopped playing DVDs I thought I saw an NSTC message come up but is it supposed to be PAL or is that the other way around. Anyway it's not working, it used to but it isn't now. Help please
When almost all TV stations went digital, analog TV signals received via an antenna all but disappeared in the United States. So you will not be able to get much, if anything at all without a digital TV connected to a cable system or a satellite system. Welcome to the new economy! You want it? You will PAY for it! Radio (first FM, then AM) will most likely be the next casualty of the new economy!
