20 Most Recent Sampo PME-50X7 50 in. HD-Ready Plasma Television Questions & Answers
Technika TV+DVD model LCD15-m3 DVD not reading
change lance tape ware or" change your lance with ccm.
5/31/2012 1:43:13 PM • Sampo PME-50X7... • Answered on May 31, 2012
3answers
Ive just been given a Technika television
have fitted a new aerial as tv was connected to sky and now cant get any freeview channels keeps saying no signal what am i doing wrong
9/3/2011 2:59:40 PM • Sampo PME-50X7... • Answered on Sep 03, 2011
Technika Pro 19" LCD TV/DVD LCD19B-M3
when i watch a dvd on my technika it is green how to i reset the settings so that the colour is normal?
10/15/2010 10:34:59 PM • Sampo PME-50X7... • Answered on Oct 15, 2010
Screen flashes, then goes blank when power turned
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems on plasma TV's are caused by overheating problems. The hardest working board in a plasma TV, is power supply board which develops voltage to supply all components, high current + high voltage. Input fuse is 10 A. Not so many TV's in history use input fuse - 10 A. Very sensitive for input AC voltage and output DC voltage. You’ll need to check this board and make sure if any capacitor is blown/swollen you have to replace it. It is only recommended to do it yourself if you have electrical expertise and know how to solder/re-solder electronic components, if not then its good to contact a repair tech.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
12/17/2009 5:03:17 AM • Sampo PME-50X7... • Answered on Dec 17, 2009
I bought this TV/DVD at Tesco. Will it play
most likely, also depends on the dvd format read your user manual to find out for sure....
11/12/2009 12:58:15 PM • Sampo PME-50X7... • Answered on Nov 12, 2009
Hi, remote not working and unable to change
if your remote is for cable, then you have to push the cable button, then change channels. volume will work only on tv mode.
10/6/2009 2:04:40 PM • Sampo PME-50X7... • Answered on Oct 06, 2009
2answers
Went from bt digital tv back to technika built in
go into source and change it onto dtv and do a fti on the unit otherwise to get back to bt digital go into source and change to scart/av/ext if no effect try a new scart lead, if is connected via hd, go into source and change to hdmi this should change it,
9/30/2009 4:00:48 PM • Sampo PME-50X7... • Answered on Sep 30, 2009
Technika pro LCD TV/DVD 15.4 HD Digital
if its the model i think it is the lcd15-m3 then go into d.menu (about 6 buttons up from the bottom left) then using the arrows next to the same button go down to the last option which should be setup or settings and press ok.
then go down to instalation (again the last option) and press ok
then down to first time instalation (again last option)
Select yes and press ok, this will bring you up to your original setup page
(menus are the same in most models but almost positive that the model you have is the m3
9/4/2009 3:34:39 PM • Sampo PME-50X7... • Answered on Sep 04, 2009
Technika Pro 19" LCD TV/DVD LCD19DVDID-308
Select the DVD and type 9 7 3 5. This brings up a new menu. Select Region 0. OK.
10/25/2008 4:49:51 PM • Sampo PME-50X7... • Answered on Oct 25, 2008
2answers
Technika LCD191d-107 LCD TV
You may want to check the solid state fuse on the power suppy or which can be called the inverter. The fuse will blow and finding a fuse can be hard.
Thanks
C Dill
9/10/2008 4:32:23 PM • Sampo PME-50X7... • Answered on Sep 10, 2008
Unit is not working,not turning on
If you know how to solder, then it shouldn't be too difficult. You can get the replacement capacitors at any electronics store or Radio Shack. The specifications will be on the capacitors itself.
5/21/2008 8:21:17 AM • Sampo PME-50X7... • Answered on May 21, 2008
0answers
Sampo PME-50X7 50 in. HD-Ready Plasma Television Logo
23 questions posted
Top Sampo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Larry
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sampo Televison & Video
Most Popular Question
ive just given technika television
  • Televison & Video
