Whats the best settings for a really good clear crisp in macro meterings , aperture .zoom lens , digital or optical , many thanks
That depends. A true macro lens allows you to get a 1:1 reproduction ratio; most manufacturers call a lens "macro" if it allows 1:4 or so. Some lenses work better for close work if you reverse them, using a reverse adaptor to put the nose of the lens onto the mount. Bellows and extension rings behind the lens will give you sharper results than close-up adaptors that screw onto the front of the lens.
The focal length will affect perspective; to get the same image size with a wide angle lens, you'll have to get closer, wihch will make the background seem smaller and farther away. You don't have to get as close with a longer lens, which will make the background seem larger and closer.
The aperture affects depth-of-field. If you're photographing something flat, like a piece of paper, you don't need much DoF. If you're photographing something three-dimensional, you'll need more DoF.
The exposure mode might depend on the lighting conditions and your personal preferences. I tend to do most of my close-up work in Manual. I also tend to focus manually, for better control.
There's no one set of "best" settings for close-up photography, any more than there's a set of "best" settings for any other type of photography.
