Like all Quantaray lenses, this lens is a very cheaply built model and so lacks the refinements, build quality and optical capabilities of better lenses. As a result, it does not have a macro mode so is not designed to focus on nearby objects.
That just leaves it as a 100-300mm telephoto zoom lens. The 100mm end may be suited to head and shoulder portrait shots (if it can focus close enough), the 300mm end is a long telephoto for subjects such as architectural close-ups and best used on a tripod or monopod to avoid unsharpness caused by camera shake. Usually a 300mm would be suited to wildlife shots, but the very slow f6.7 maximum aperture at this end really limits this function to non-moving objects simply due to the longer shutter speeds required to compensate. You could turn up the ISO sensitivity, but then you get noisy images...You may find that the maximum aperture at around 200mm is around f5.6, this is still quite poor but far more useful and as long as the light levels allow a 1/200th or faster shutter speed it should also be possible to hand hold the lens without worrying about camera shake. If your camera has seven megapixels or more, then shooting at 200mm and then cropping the shot afterwards to achieve the same view as a 300mm will probably give better results.
Your lens has it's limitations, but a good photographer will learn to work around them when necessary and to embrace them as needed. The 100-300 is known to be a very poor optical performer, but for portrait work a soft lens can be used to good effect. At the end of the day, it's a US$100 lens so you can't expect that much from it but you as the photographer can make a lot of difference by using it creatively.
I hope that I've helped, if so please take a moment to rate my answer.
