Jura Capresso 454 10-Cup Coffee Maker Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I add water but it won't pump the water
I add water to my Capresso - 10 cup coffemaker but it won't pump the water.
eyecam
Level 2:
New Friend:
  • Expert 100 Answers
  • Posted on Mar 16, 2010
eyecam
Expert
Level 2:
New Friend:
Answers
100
Questions
0
Helped
39876
Points
183
Check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Repair Capresso CoffeeTEAM GS No heat Wont Pump Water
Check the elements. Unit heats water and forces that heated water out.
The pump stops working and then brews a cup and stops again
initially try to descale your unit if the problem persist you have to check the pump.
6helpful
My Cuisinart DTC -975 coffemaker fails to pump water. I turn it on then after twoo minutes it beeps and then shut-off. Why is it doing this and is it fixable?
My Cuisinart Espresso Maker EM-200 won't pump the water in and then the manual, one cup, and two cup lights come one and they flash and beep. What am I doing wrong?
If i try to make more than 6 or 8 cups in my 10 cup bunn coffemaker. The coffee grounds overflow . This is a new coffee maker and we find a mess almost every time we make a pot. We have alwats used bunn...
This can occur with the use of finer ground coffee or use of soft water, filtered water, or bottled water. If you will call 800-352-2866 with the model and date code, we can send you a flow restrictor sprayhead which will alleviate this problem.
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Coffee doesn't brew full pot
-Tha Mp3 Doctor
2helpful
What is the best way to clean my cuisinart coffee maker?
-Tha Mp3 Doctor
1helpful
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
-Tha Mp3 Doctor
1helpful
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
-Tha Mp3 Doctor
3helpful
2answers
Jura capresso
If you gind too fine, it will overload the pump and result in the "open tap" a few seconds into brew. Rinse and gind coarser to clear out malfunction.
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
