1998 Ford Windstar Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't change from defrost to dash vents. I think it is a vacuum problem.
Anonymous
Level 2:
Scholar:
  • Expert 185 Answers
  • Posted on Mar 13, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
185
Questions
0
Helped
63105
Points
497
Ther vacuum control line is leaking. This usually occur very close to the 3 way junction. Check on the passenger side under the hood,for a small RED plastic hose, that connects between the connection on the firewall and the rubber junction.
The break is usually in this RED tube.
It is usually glued in place, but can be separated with a little elbow grease.
If you disconnect and examine it close to the end, you will see the break usually wher it bends.
It is usually safe to cut it wher it break and reconnect it, and it should work fine after.
WARNING!! Before you do any repairs on this car you should first disconnect the negative ground.
Otherwise the computer may not recognize the repairs for a while after.
Mike
Level 3:
  • Ford Master 4,383 Answers
  • Posted on Mar 11, 2010
Mike
Ford Master
Level 3:
Answers
4383
Questions
Helped
1261620
Points
17064
Yes, something is broken, the system is set to fail in the defrost mode, perhaps by law. Look for broken or loose vaccuum lines. If nothing is loose or missing, then progress through the control system, to the slave motors (actuators).
Vents won't switch in my 98 Oldsmobile regency
Not under the hood. The "mode" door, actuator and vacuum lines are on the heater box under your dash.
Does the Erg vacuum solenoid cause the ac switching from vents to defrost
the ERG shouldn't have anything to do with what vents the AC comes out of, rather the dash switch that exists for changing from defrost to main vents to floor vents controls what vents are used.
2answers
1998 chevy blazer heater problems. wont switch from defrost to floor. stuck on vents right now. how do I fix this problem.
Most likely either the vent switching mechanism is dirty and won't switch the flaps -or- most likely the vacuum that is used to turn the vent flaps is either leaking and not pulling enough vacuum. You will have to get underneath the dash near the center, to check and see if you can manually move the vent flaps. If so, then most likely it is a vacuum leak in a vacuum line to the flap mechanism.
Vacuum vent control
You will need to look at the area behind the dash to see if a line was left unhooked at the control panel for the a/c defroster selector. If as you said, a line was burned, you will need to find it further back behind the dash and replace it. An unhooked line will need to be reattached to a small device that may look like a bellows. The are back there is tight but if you had work done, you hopefully still have it open from the front. Any parts store can sell you the vacuum line you will need for this fix. Good luck.
1helpful
2answers
Air only comes out defrost in all settings
I just fixed mine. The lever that opens and closes a door that directs the air flow to the defroster was broken. To be more specific, the plastic lever the actuator attaches to was broken. The actuator and the vacuum system were operating properly. It is simple to see but hard to get to. Remove the glove box and look up and to the left for a silver vacuum controlled actuator. I was able to fabricate another lever and attach it to what was left of the OEM lever.
4helpful
My 1997 ford ranger a/c dash vents won't blow
Vacuum supply starts on the drivers side of the engine. There is a vacuum line going into the brake vacuum assist from the manifold. branching off of that line is a double line that snakes under the intake manifold, behind the valve cover, along side the valve cover on the passenger side headed to the front of the engine. Then it curves to the right side of the engine. One set of hoses from this line goes to a valve control (red and green i think). The other line goes to the vacuum storage ball, it should be black. The vacuum circuit continues out of the ball in another black line that snakes into the firewall. It goes under the heater core black box and disappears under it. Now go into the passenger compartment and drop the glovebox. look to the back right you will see a black and a white vacuum line coming out of the firewall. The black line is your vacuum supply from the engine. It goes up to a little rubber manifold. disconnect the lines coming from the dash switch and check for vacuum on the manifold where the black line is going in. The white line controls the cabin air intake under the glovebox and the thermostat shutoff under the hood. It should only have vacuum when the switch is in a certian position, AC probly. The other three lines coming off the rubber manifold snake behind the dash vent door assemble and come out near the gas peddle. The red one controls the dash vent. apply vacuum to the red hose and see if the vents go to the center dash position/AC. The yellow and blue? ones control the floor vent control near the gas peddle. yellow gives you half floor and half defrost. blue gives you all floor. you can use a small vacuum line to connect the black vacuum supply to each individual line on the manifold and check the function of each vacuum control assembly individually. I hope this helps. On my truck each control unit works fine when i apply vacuum to them individually but when I hook the dash switch up to the rubber manifold it goes to defrost. I tried changing the dash switch and the lines running from the switch to the rubber manifold and the vacuum ball under the hood, nothing works. I suspect I may have leak i just haven't found yet. next step is to get a vacuum gage and start checking the amount of vacuum i am getting at each vacuum line. I'm sure it is supposed to be getting a specific amount of vacuum and will not work if the vacuum drops below a certian level due to a leak in a line somewhere? God bless.
1helpful
Vent control for climate control does not change positions
Air will only come out of the defrost vents on the dash i assume? The defrost vent is the default position when the system looses vacuum. Under the hood look for a broken or disconnected vacuum line on or near the engine in the area of the passenger side of the firewall. You may even hear the a slight "hisss" indicating a vacuum leak. Reconnecting the line to the appropriate port will restore proper vent operation.
6helpful
4answers
Heating / air conditioning control stuck to front defrost vents
There is a vacuum leak under the hood. Find the vacuum line on the passenger side where it comes through the firewall and follow it to the engine. You system needs vacuum to operate and without it the default setting is on defrost for safety reasons.
Air won't come out of vents, but will from defrost and floor.
if it switches function even only a few then the problem is not the vacuum source (if u had no vacuum it would default to defrost mode) the problem is the dash control head vacuum mode control switch, i don't think u can just replace the switch, u have to buy the whole climate control module.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
