Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magic touch whirlpool switch won't stay on.
Asteria Bath Series
Model 9740
The motor turns on when switch is pressed in, but shuts off when released.
Motor stays on only as long as the switch is depressed.
Anonymous
Level 2:
Champion:
  • Expert 225 Answers
  • Posted on Mar 07, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
225
Questions
0
Helped
144986
Points
371
Jacuzzi Asteria will not turn off
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
I have a HydroAir Magna Series Whirlpool pump model #LD7AC that will not shut off with the airswitch. The airswitch does not appear to be disconnected nor does the tubing appear to be clogged. Any...
If your bath pump LD7A-C will not shut off when you push the air button then the AIR SWITCH in the motor needs to be replaced.
This is a pretty common problem with Bath Pumps and easily fixed.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 • Home
1helpful
Hydroair magna series whirlpool pump model #LD7AC airswitch does not work. It appears to be connected properly and not blocked. Any suggestions?
If your Bath Pump will not shut off when you push the Air Button, it sounds as if the Air Switch is not working in your Bath Pump.
Click on the Air Switch name and it will show you the replacement part you need to fix the Bath Pump.
Rod
US Parts Center
888-521-6183
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
2helpful
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 • Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
I have a Jacuzzi Whirlpool Bath (Torino model) whose Magic Touch On/Off (button) Switch has suddenly ceased to respond (does not turn on.) Are there any troubleshooting tips/possible reasons short of a...
The Magic Touch control has been discontinued now for some years. You will need to remove it and install a control that will have it operate with an air switch/air button system. This is a pretty simple fix but will run you right around $70 for an Air Switch Kit.
US Parts Center
1helpful
2answers
Installing an Aqualux (Desiree) whirlpool bathtub
call the manufacturer Asteria Bath Company at1-800-288-4002 and they can send it to your email address.
Nov 02, 2008 • Home
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
