Sony KP-61S65 61" Rear Projection Television Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony projection screen tv the colors are not lined up and i am try to find out how to adjust them so it works again
Donnie Wayne Sharp
Level 2:
  • Expert 132 Answers
  • Posted on Mar 02, 2010
Donnie Wayne Sharp
Expert
Level 2:
Answers
132
Questions
0
Helped
26207
Points
400
I think your convergence is out of align. I looked at the manual on the sony site. Setting it starts on page 14. If you don't have the manual you can find it here http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP61S65
1 Related Answer
Anonymous
  • 13 Answers
  • Posted on Jul 27, 2009
SOURCE: 3D look screen,color don't line up,bowed screen,
It is usually the heat sinks or the convergence chips need replaced.
1helpful
Color convergence and color looks 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Picture red and blue shadowing
•Screen looks 3D
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
3d effect on left side of screen
•Screen looks 3D
2answers
TV will not come on
i have a sony rear projection TV, model number kp43t70 screen went black and there was still volume but no pic so I turned it off and now won't turn back on
2helpful
Sony TV losing focus
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
1helpful
2answers
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
How do i get my tv to show the picture straight
THE IS A BOTTON FOR THE ALIGNMENT UNDER THE POWER BUTTON. CLICK ON IT AND SEE IF IT CLEARS. IF THAT DON'T WORK LOG ON TO THE WEBSITE BELOW AND READ ABOUT THE COLOR ADJUSTMENT FOR THE SCREEN VOLTAGES. IF THAT DOESN'T CALL A PREFERRED SONY REPAIR SHOP FOR ADVICE.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
3helpful
10answers
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
