the catridge may be about to finish and the mixing is not properly taking place.
the outlet from the catridge may be blocked so reqired amount of ink is not flowing out from it.
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there. To clear all pending job In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer. Have a nice day and do not forget to rate please...!
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
You have to install the printer through it installer, it that way the advanced features of the printer will be activated and can be manually configured to what you want.
