Philips Magnavox 27MS343S 27" TV Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv works fine until you turn it off, when you turn it back on the green light shuts off and the tv totally dies, the red light thats on when its turned off is not working either. Now if you unplug it for about 5 min. the red light comes back on and when you press power it begins to start then completley dies . if you keep repeating this it will eventually stay on, usally takes about a half an hour or more. Once you get it to turn on it works perfectly.
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Feb 21, 2010
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336716
Points
2402
Check all caps in the power supply especially the 10mf 22vols cap.the caps are not filtering the voltage properly when the the current i off the caps drain the voltage and does not keep charging.until when current is applied to the set.good luck.
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
1helpful
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
1helpful
2answers
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance
4answers
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
2answers
Will not turn on
We turned the tv off to go outside. Then when we came back in, our tv doen't want to come on. Green light comes on and then it goes back too red. It keeps doing that until u unplug it
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
