20 Most Recent Sylvania LD320SSX LCD TV Questions & Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sylvania... | Answered on Oct 11, 2015
Without a remote control; you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name" of your device, in the search box [at the top right] of the display window and press Enter. It will make surf easy.
Sylvania... | Answered on Jun 03, 2015
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Sylvania... | Answered on Mar 02, 2015
Sylvania... | Answered on Oct 28, 2014
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Contact any service technician. Anyway, to repair it, its remote control is a must. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Sylvania... | Answered on Jun 23, 2014
Sylvania LD320SSX LCD TV Logo
101 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
no remote in sylvania just flashes
  • Televison & Video
