Garmin Golf Logix GPS Logo
Ian Alexander Posted on Feb 20, 2010
Network error cannot find the host - Garmin Golf Logix GPS
Anonymous
Level 1:
New Friend:
  • Contributor 63 Answers
  • Posted on Aug 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
63
Questions
0
Helped
11426
Points
80
Update your phone to the 4.7 firmware at blackberry.com
2answers
System requirements to eliminate QuickBooks hosting mode is off
QuickBooks has made it easier for everybody to access the company file from the server or host system. But, if somehow you come across the error QuickBooks hosting mode is off, then the scenario will become entirely different and complicated for you. Therefore, there are some requirements that you must follow if you do not want yourself to stick in the same situation:
1. You must save your QuickBooks Company file in a shared folder.
2. Your system must be set for the multi-user mode.
3. As a user, you need to map the server or the host system as the network drive for each and individual workstation.
If any query regarding the resolution of QuickBooks hosting mode is off persists, feel-free to get in touch with our experts.
Proxy error code: c004c009
This error code suggests that the Host is being used by someone else
I can not connect using grabit the error 119 code can not connect after checking most other things out I think it's the router stopping conection of this programme can help me?
Hi ....
This error message appears if:
  • An error at the TCP or IP layer has occurred.
  • The other host has gone down.
  • The network between the gateway computer and the other host has gone down.
You can test these possible causes by attempting to telnet to port 25 of the smarthost and resending the message. This can usually be done by pressing SPACEBAR and typing "25" (without the quotation marks) after the IP address on the telnet command line.
If the error message appears frequently, check the network with a protocol analyzer to determine the exact problem.
Thanks ....
With regards .....
Priya
Golf logix for my blackberry ' network error, cannot find host'
If you have verizon, you need to turn GPS services to location on (options, advanced options, GPS) and you need to make all the permissions for the program "Allow"
How to solve this in HP DP express "50 SBERR_SOCKET_CONNECT Socket connect error Data Protector Express is unable to connect to a remote host"
Check that the server is connecting thru the same Network card by checking the IP address.
Check that the network agent license is properly installed on the Storage domain host.
Check it is communicating thru Port 3817.
Persistent "network host busy" error
After working with Lexmark tech support (which is excellent, by the way), it became clear that the problem is with my network (Airport/Time Capsule) and not the printer. (The printer works when plugged directly into my computer.)
4helpful
4answers
Scan cannot be performed
I also had the same problem with HP Officejet 6310 and after trying all the solutions that I could find on the web, I was almost giving up. Then I found this on HP's IT Resource Center website (author J.Eqbal) and tried it and finally it scanned without the error message.
This error happens only in Network connections.
Get the Ip address of the Printer and open the EWS page by typing i.e http://192.168.1.102...where 192.168.x.x.x is the IP address of the Printer.
On the EWS page click on Network and get the host name and copy it.
go to the following location C:\Windows\System32\drivers\etc...inside etc you will find the host file open it using notepad.
Underneath 127.0.0.1 local host
there might be the Ip address and host name ..which will be different from the current host name...change the Ip address and host name ..save the file.
Try to scan...it will definitely work.
MySQL can't connect Error
Guess you are referring to this error message -
Check your username & password, and make sure that you are authorized to access the server.
If your password & username are correct, there might be a network problem that prevents you from connecting to the machine where the MySQL server is running. To make sure that they are no network failures, click on the "ping" button.
This will "Ping" the MySQL server host. If the host is available (no network failure), you will
receive a message similar to this -
Reply from 127.0.0.1: Time=0ms TTL=128
Reply from 127.0.0.1: Time=1ms TTL=128
If you don't it means there's a problem with the network.
Jul 27, 2008 • Sun MySQL
2answers
Destination host unreachable
Hi you should check your network settings ie IP ADDRESS, DNS etc, and also check to see that your proxy settings are unticked. John
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
