Sirs: I'm hoping you can help me with my problem. I'm running
the CrosleyCR240 Songwriter.
All is working well except for the CD drawer. It will not open it sounds
like it wants to but it does not. Is this a serious repair or can I
do it myself? If I can, could you please give me that info.
I'm in Bellmore, LI NY and if you could recommend me to a repair shop in Nassau County
that would help.
Thanks, Steven Duquette 516 221 0559
SOURCE: crosley songwriter cd recording problem
the cd drawer will not open, I can hear it trying to engage and open but it won't.
SOURCE: cd drawer wont open cr248
I have the Crosley CR247 which is the same except for style. I had same problem.
The CD drawer stuck and would not open. It made sounds like it was trying. I could not find any information on a solution, but from what I had been reading on other CD Drawer problems, it sounded to me like there had to be a manual emergency release somewhere. Could not see one anywhere on the unit, so I took a butter knife and inserted in the crack just below the tray. I slide the knife from left to right and just very gently ppressed around with it. When I had it over to the far left hand side moving it over just about an inch and a half to two inches, I just slid the knife from side to side and it opened. Sorry, I am not a mechanic or do not know how to fix things, so this is the best that I can do to explain where the emergency release is located. My little rubber belt drive looked good, so that wasnt the problem. I just opened and closed my drawere about five or six times before I felt that it was safe to stick CD in. I don't use it much, maybe that was the problem. The trick is getting the darn door open first so that you can see if it is the belt drive or not. Good Luck to anyone with the same problem.
