SOURCE: Oven gives me an -F3- message and stops working
F3 - E0
Oven temperature sensor or oven temperature sensor fuse opened
Replace oven temperature sensor or fuse
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Self Cleaning Feature..Lost my manual
Kenmore posts manuals online at http://www.managemyhome.com/mmh/ .
You will need to register your email first and then search by model number.
SOURCE: oven won't heat up
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
SOURCE: My Kenmore Elite 790 when set to bake or preheat,
door doesnt completely close when baking with kenmore elite 7903670 very frustrating
SOURCE: oven door remains locked after using the oven cleaning feature
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
