When I plug in the 7000 PT the display only flashes, it will not power on. And behind the side panel there is a red light flashing and making a clicking sound.
Thanks in advance for any help you can give me.
Hi, did you ever figure out what was wrong ? I'm having the same issue with the same model stairmaster. The clicking stops when i disconnect the cable from behind the console...
On that relay board their should be 2 lights engaged:
1.power
2.relay.
It sound like a loose connections there are 3 connections to the board first that I would look is the power connections to see if their is no broken wires, than the connector that goes to the display that may have exposed wires that may be grounding out on the frame and by jostling the connectors and see if either one stops the light flickering and relay clicking.Their can be also cold soldier connection on the relay board. Hope this helps
