Open the image with ANY image editor on a computer (Paint will do just fine) and click "File -> Save As" choose filetype .jpeg and give it a new name. Whe this is done, try to load it again on the projector.
This way you just try to reformat the image in to the jpeg format. If this dose not work, your projector are probably not going to display jpegs at all.
If this still dose not work, you may want to consider formatting the device you put into the projector (If it is a usb, sd card or similar) to ensure it is clean, i suggest formatting to FAT32 as this is most commonly supported by peripheral devices. Aaaand try again ;)
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
they need to be files of mp4 video filetype dude !!!
mkv , wmv, avi, mov, and H.264 will only return a message "file not supported" if you grab "youtube downloader" free off the net, use the convert feature and select ipad video setting, and "quality as original" and convert the video files to mp4 buddy .....do a few...to test them, and connect your device to the Tv...they will work guaranteed .....then just spend a bit of time converting all your video files to mp4 video, ohhh you might want to delete origianal file after conversion as well after you tested a few converts....reason why is the converter actually clones the original file making a new copy of the file, you will still have th original file there and will be hard to identify which is which by looking at a thumbnail. Remember This Tv can only read filetypes of ">
So use the youtube downloader convert feature and do a convert buddy and your Tv will play em !
This model's characteristics are "Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both straight-Through and Cross-Over cable." The rest u can visit this link and satisfy yourself. NOTE: VISTA might not support this router since its been discontinued manufacture of this device quite some time back. The link is : http://www.dlink.com.au/tech/Download/download.aspx?product=DI-524&revision=REV_B&filetype=Firmware..................sodeep
