I have a Sharp AL-1641CS copier..The toner light came on once and then went off the copier worked for several weeks...Now when I try to use it it just makes a clicking noise when I press the copy button....Nothing else happens...I can't afford to buy a new toner cartridge just to see if that is the problem....I am a homeschooling mom of three and I need my copier to work...Help
Would
you like to review the features of the Sharp AL-1641CS Copier?
Have
you lost your Sharp AL-1641CS Copier Owner's Guide?
Would
you like a free digital, searchable, pdf version of the Sharp AL-1641CS
Copier Manual? Follow this link (& click
FREE)
to download a pdf version of the Sharp AL-1641CS Copier
documentation.
Would
Have
Would
you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual? Follow this link (& click
FREE)
documentation.
SOUNDS LIKE YOU NEED TO REPLACE THE TONER CARTRIDGE, THEY GO THRU LONGER WARM-UP PERIODS WHEN THE TONER GETS LOW AND IF YOU LET IT RUN YOU WILL SEE RED LIGHTS LIKE STACKED CANNON BALLS, WHICH MEANS ITS OUT OF TONER
those dots mean toner, when they blink it's empty. replace the toner cartridge. open the front door and pull it out. pull the seal on the new toner and slide it in. shut the door. that was easy! Good Luck!
Most likely you had a toner cartridge failuer leaving some of the ink and developer in the crevices above the paper feeder and its just trickling onto the paper.
It pretty much needs to have the cartrides taken out and thouroghly vaccumed.
Just takes patience and time to get it all removed.
Dont vacuum the cartridges, but the inside of the machine.
Pull your paper tray out and see if there is toner and developer trickling into it.
