Hello, I have a 52525 and the lamp indicator went solid red- I replaced the lamp - the timer resets and then the lamp indicator goes solid red again- i replaced the lamp a second time and the same issue occured. What should I try next? Help
Push the menu and device buttons on the front of the set both in together and hold for 6 seconds and see what two digit error codes blinks. It will most likely blink a 3 pause then 4 and then repeat the sequence indicating a 34 error for lamp abnormality which is almost always caused by faile capacitors on the Power pwb.
