2004 YUKON XL DENALI, 6 liter engine - recently had "low engine power" error message pop up so took to the dealer who diagnosed as failing throttle, so they replaced. Now, the shift points seem to be delayed and the engine winds up totally when kicking down the accelerator pedal for passing at highway speeds. What's up with this - how do we fix? Dealer says mechanical issues with tranny. I think not- your thoughts?
I recently had a low engine power on my 2003 Denali. The check engine light came on and I couldn't go above 40 mph. I took it in the next morning but by this time the check engine light had gone off. The mechanic had just recently seen the same problem in another Denali in which they changed the battery and had no problems since. I also decided to have them change out my battery and I have not had the problem since either. I would stay away from the dealership if I were you, and always get a second opinion. Most smaller shops wont charge for a diagnostic where the dealership will charge at least 80 just to tell you what might be wrong and that will only work if you have a warning light on at the time.
