Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Tried that already. Thinking it might be the power board. Or at least hoping that it might be the problem.
