Motorola Mobility RAZR v3xx  Cell Phone Logo
Posted on Jan 06, 2010
Razr v3xx broken flex cable
I have a cingular/at&t razr v3xx phone with a broken flex cable...no, not the keypad cable, but the other one for the "top". the chinese have conspired to send me a flex cable that has fewer pins than my original and they refuse to work with me to get the "right" cable. why is this phone special and where can i find the right cable?
balakumar
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 10 Answers
  • Posted on Sep 10, 2019
balakumar
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
10
Questions
0
Helped
5088
Points
33
Inter cell cable and Lead connector in Chennai are mostly used for phone cells. We Provide the Complete Solution to people for Battery Technology
Anonymous
Level 1:
New Friend:
  • Contributor 84 Answers
  • Posted on May 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
84
Questions
0
Helped
20716
Points
99
Is this one ? http://www.ownta.com/original-motorola-v3xx-cell-phone-small-flex-cable-with-ic.html
You'd better provide picture to them before you buy from ownta.com.
Good Luck !
1helpful
Motorla razr v3xx
well pop the back off ,remove the battery.then there are 2 screws that hold the modem in place.remove them and very carefully pry the modem off.there are 2 plastic tabs near the bottom of the phone 1 on each side.careful or they will break.`then there are 4 screws on each side of the screen,when opened..they are under little rubber pucks.remove them and separate the 2 half's..Unplug the flex cable from the screen and carefully remove the screen and camera assembly.be carefully not to tear off the flex cables that hold the 3 buttons on the screen in..then if you'll turn the phone back over.where the battery goes in on the hinge .you'll see another screw.remove that and flip the phone over again.carefully pop the chrome hinge pin out.then you'll be able to separate the 2 half's.then there are 6 little metal tabs that hold the keyboard in place.pry them up and carefully remove the keyboard and flex cable.careful around the hinge,where the flex cable runs threw.
now moving on to the modem, on the bottom you'll see 2 little plastic tabs carefully open them and remove the brass retaining wire and the modem will then come out..get your new covers and reverse this process and you'll be good to go.
2helpful
For to check the firmware version in the motorola v3xx device
Under an ATT/Cingular phone you can simply go to Settings>Phone Status>Other Information, where it should show two items: Flex Version & S/W Version. Two items that will let you know what firmware your phone is using to operate its components as well as the software side. Should be easy to find on most branded or global firmwared phones. Hope this helps.
Motorola v3xx got wet
you may have short circuited the flex cable connecting your screen to your mainboard, in this case you will have to buy a new flex cable
Problem with motorola v3xx
Hi sir, your keypad flex cable sounds like the issue. It is a common issue with razr. Problem is caused by regular wear and tear.
costs about $20-35 for the repair
http://horizonwirelessonline.com
Motorol V3XX
Either the technician didn't actually change the keyboard flex or you have water damage on the phone.
I
RAZR cell phone
try changing the flex... keypad circuit goes with it...but have it changed by an expert technician since it's a very complicated task
Motorola razr v3xx
it would be best to go have the phone firmware reflash and the card reformatted.
Razr V3XX rebooting iteslf
hi
it seems your phone has a hardware problem... usually its flash ic.. have it reworked...
hope it get better...
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
 Mikey
Mikey
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
