Nikon Coolpix 4300 Digital Camera Logo
Posted on Jan 05, 2010
I can no longer transfer photos from my Coolpix 4300 to the computer. Is it a camera or lead fault pls?
dblclutch
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Feb 15, 2010
dblclutch
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
4456
Points
13
Problem could be either a lead or might be within the camera. Remove your memory card and insert it in the card reader on your computer. If it reads okay and transfers the photos then take a few more photos and try again using the camera connected to the compter. If it fails again try a new connecting cord. Good luck.
HOW TO DOWNLOAD PHOTOS FROM NIKON COOLPIX L11 TO MACBOOK
Three ways. Here are the best 2, or the software that came with it.
Import photos from a camera or phone using Photos on Mac ...
https://support.apple.com > en-ca > guide > photos > mac
Use Photos on your Mac to import photos and videos from your camera, phone, or other mobile device.
User's Manual
https://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L11_L10en.pdf
coolpix > L11_L10enPDF
May 15, 2007 - Thank you for your purchase of a Nikon COOLPIX L11/COOLPIX L10 digital camera. ... delete, or transfer pictures from the internal memory.135 pages
Transferring Pictures from a Nikon DSLR to a Computer ...
https://www.dummies.com/photography/cameras/nikon-camera/transferring-pictures-from-a-nikon-dslr-to-a-computer/
Connecting a Nikon DSLR to your computer for picture download - With a card reader, you simply pop the memory card out of your camera and into the ...
How can I remove the arrow that appears on the left hand side of pictures taken.
The only arrow I can find is a double arrow, projected for the files which are selected to transfer too the computer.
It is on page 32 of the manual.
link to manual Nikon CoolPix 4300
Trying to transfer photos from camera to computer. Have been doing in successfully for years. Today it says "Communications Error" and the photos will not transfer.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Camera is no longer recognized by the computer when connected through the USB port; I have already replaced the cable and checked it on different computers.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Require software to transfer photos
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
When i try to take photos from my nikon coolpix l20 whith nikon transfer computer display " connection between camera and computer was diconnected" help me pls
Consider NOT connecting your camera to your computer.
2helpful
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
2answers
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Folders/photos in coolpix 4300 not visible on computer
Come off line and disable to Anti virus and then try.
If you still have trouble then stop using the camera to upload and buy in stead a USB card reader.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
